SOURCE: John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
