SOURCE: Where is the defrost timer kenmore side by side 596.52679200
Adaptive Defrost Control will be your timer, Good Luck, Sea Breeze
SOURCE: defroster timer on kenmore model 363.9532711
in the fridge part behind the plastic cover protecting the light. Its on the right side. Remove the two caps to the selectors and take the plastic cover off.
SOURCE: kenmore bottom freezer refrigerator model
it may not have a timer but a aditive defrost control . most common with newer model .. its located in the fresh food side just behind the thempt contro knob and its a pc board .. . . do ck your heater first and the defrost terminator as thes two parts ore more common to cause your freeze up .. mm
SOURCE: kenmore refrigerator model 253.67873509 freezer
First off, go to this web site and enter your model number- it should have more letters in it than numbers (the number you provided might be a serial number, not sure):
http://www.appliancepartspros.com/
This should give you some diagrams and parts lists.
This following web page describes your problem, and how you can fix it:
http://www.appliance-repair-it.com/refrigerator-not-cooling-evaporator-coil-freezing-up.html
Once you get the coils defrosted, a friend of mine said if you wrap a piece of copper wire across the two evaporator coils, and connect them, the coils will not ice up. I never tried this myself, but it might be worth trying.
Good luck, and hope this helps.
