Setting for 38 degrees in refrigerator section but goes below that, already checked that nothing is blocked, what else can I do? Model #596.7760
SOURCE: Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up. Defrost completely to allow the passages to get a free flow of cold air.
SOURCE: Fresh food section not maintaining cold temp
You're frozen up. Defrost completely. Then, clean your condenser. Make sure to never leave open containers in the fridge...water condenses into ice. If you still have problems, you may be low on gas.
SOURCE: Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
There can be many reasons why your
refrigerator is freezing your food. To see what could be happening
and to figure out how to possibly fix your problem. Take a look at
this tip which contains many of the causes and solutions to fix the
problems.
Refrigerator
is Too Cold and Freezing Food
heatman101
