SOURCE: cuisinart food processor DLC 8 Plus - can't unlock new bowl
I just had the same problem! I gently tapped the the bottom of the handle with a hammer in a clockwise direction. It finally unlocked and is now working fine. Good luck!
SOURCE: need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
SOURCE: I have a very old cuisinart food processor
Unfortunately the CHM models no longer have replacement parts. If the workbowl parts says something like DLC-7 or DLC-10, then you can call Cuisinart and get replacement parts. CHM models would require finding somthing on eBay.
SOURCE: My Cuisinart food processor won't start!
Make sure work bowl handle is locked in so that the handle is facing the front of the processor, and that the feed tube and metal rod of the pusher are facing the back of the processor. If it is assembled in this way and still won't turn on, call Cuisinart for assistance, as you may have concelaed damage to one of the work bowl parts. 1-800-726-0190
SOURCE: I just go a foodnetwork 12 cup food processor and
The same thing happened to me. I took it back to Kohls. It was 1 year old and I only used it like 4 times. The motor would run but the blade wouldn't turn. Maybe because Kohls is busy this time of year, the Customer Service guy didn't even ask when we bought it. It was obviously last year's model because the color was white not the current black. Anyway, the FN Food Processor says they have a 2 year warranty so that could be route you could take also. I know this isn't REALLY fixing YOUR food processor, but it would fix your problem.
Testimonial: "I took mine back the next day and without a question they replaced mine and it works just fine!"
I'm not sure about that particular food processor but I just bought a ......
Wolfgang Puck 12 Cup Food Processor
It's absolutely amazing, on the Shopping they have a huge sale on them with free shipping!
That probably doesn't help you but thought I would pass this Food Processor on!!!
I wish you Good luck with finding your Braun or what your looking for!
Cheers!
