Dewalt DPD3100 Gas Pressure Washer Logo
Alexandria Gamble Posted on Jun 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my pressure surge - Dewalt DPD3100 Gas Pressure Washer
Paul Cofrancesco
Level 2:
Filmmaker:
Uploaded 5 video answers.
Scholar:
  • Expert 97 Answers
  • Posted on Jun 04, 2014
Paul Cofrancesco
Expert
Level 2:
Filmmaker:
Scholar:
Answers
97
Questions
0
Helped
37663
Points
257
Common problem across brands. When you spray water the drop in pressure triggers the motor to take the hose pressure ~ 30 psi and boost it to ~ 3000 psi. Water coats these parts with calcium (hard water) or other junk and water contains bacteria which causes slime and scale. Once that pressure switch / valve is sufficiently clogged it doesn't move smoothly so it can fluctuate between sending a yes / no signal about whether you are squeezing the trigger or not. This causes the pulsing.
EZ test: take the the tip off the wand, start the unit, squeeze trigger - should run continously with no problem. If it does for sure you need to watch a video on dissembling and cleaning the valve body. It is not hard but you must work carefully to avoid losing parts especially springs and take digital pictures to record the order for reassembly.
2answers
I have a Black Max 2600 PSI pressure washer, model BM80913, that gives a surge of pressure, and then pressure drops off. Solution?
Pump needs to be rebuilt or replaced, some of those pumps have a replacement surge valve inside, some do not
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 • Psi Garden
1helpful
Constant surging 1989 chevy cheyenne 5.7 replaced fuel filter checked air intake replaced EMC tune up done. checked hoses for leaks. Still surges and can't get any codes including code 12.
I suggest putting a pressure gauge on the fuel line bleeder valve and check the pressure coming from the pump. If the pump is getting weak it will cause the truck to surge. Could also be the catalytic converter stopping up as well. I'd check fuel pressure first. Hope this helps you out.
Pressure washer surges
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
I need to find a leak in my coolant system. Where do i hook up the pressure tester on my saturn?
HOOK PRESSURE TESTER ON THE COOLANT OVERFLOW OR SURGE TANK, FIRST REMOVE THE RADIATOR CAP.PRESSURE TESTER SCREWS ON TOP SURGE TANK.YOU NEED THE BLACK LIGHT TO SEE COOLANT LEAKS.
Power surging when accelerating
Fuel pressure Normal range is 35 to 70 PSI. Without the proper fuel pressure needed the vehicle surges and looses power especially goin up hill and at WOT(wide open throttle) . Its a good call if you change full filter your going to any way. you got a surge going on. Also check the airfilter once that plugs up it will also cause the surge. Surges happen when it lacks something so your getting less of some thing
1helpful
Lots of water on basement floor at pressure tank.
sounds like the bladder tank at the well is ruptured this will cause pressure surge, and pump short cycling, and needs to be replaced asap.
When I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
5helpful
1helpful
When motor is at idle speed it surges
Try a simple test. It is ok to run the pump without water for a short time. Check idle speed without water in system to see if enginet surges. If it does not surge, then most likely the unloader/ pressure valve is causing the engine to surge when in the unloaded state. Life of unloader /pressure valve is shortened by letting system bypass for long periods of time. Enjoy
Nov 22, 2008 • Garden
Top Dewalt Garden Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
