SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
SOURCE: Hi, I have an Asus
Since the battery totally ran out, hence, now you require to charge it back up kindly do not try to switch on your laptop any more unless you have left it on charger for a minimum of 8 hrs. In case even after charging for 8 hrs it is doing the same thing i.e. logging off then, press f8 key while booting up and from the selection select last good known configuration and hit enter. That will fix everything. In few cases it's also f10 button hence try both f8 and f10.
Testimonial: "Thank you so much, I didn't know who to turn to but my problem was solved so quickly, and in layman's terms!"
SOURCE: After pressing the power button
It seems that your laptop didn't pass the power on self test. meaning there's something wrong with the motherboard or the power supply.
here are the things that you can try:
1. remove the battery and the charger.
2. press and hold the power button for 5 secs. without the battery and charger. the reason for this is to drain flea power.
3. then plug-in the charger only. (make sure the battery is not connected).
4. power on the laptop.
note: If the laptop comes on normally, the laptop encountered a glitch. sometimes by draining the flea power or static electricity will resolve the problem. If it didn't come up, you need to contact your manufacturer.there's a possibility that your motherboard is already fried.
good luck,
Ryan
SOURCE: my asus laptop's power button need to press several times to start...plz help
i have a problem like this, when i press the power button it's fan start and system start but there is nothing on display, after a while automatically it'll be off or i have to hold the power button and turn it off and try again, every day times of this try increase, one time i tried for an hour to turn it on!!! so i send it for guarantee service. they repaired it but still sometimes i have this problem, and i worry to be worse again in time
