This means unbalanced load. The inner basket is supposed to raise up about an inch after water enters machine. If this does not happen you will get UL error code. Usually the inner tub gets hung up and won't move upward. You can get video of how to remedy this problem on utube. Inner tub must be removed to inspect the drive tube shaft
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
