SOURCE: EFO?
It cud b coz of a plugged up drain hose..check that...&
After that..unplug the machine for 5mins and plug it back again..if the message occurs when u r doing a load on the 'bulky' setting (blankets and the like). use t normal settings.
Another important aspect that u must observe is that it cud b becoz of unavailability of hot water..plz check that too
SOURCE: error code E10 on frigidaire
I have the same problem. I'm going to search the frigidaire web sight
SOURCE: Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: I have an Frigidaire Affinity
Hello
& Welcome to FixYa E41
error indicates that the problem is with door lock assembly, it is displayed
when the control board thinks that the door switch is open. To solve this
problem you have to remove the door lock assembly and measure the resistance of
the PTC. If it reads open then the door lock assembly needs replacement
however, if the reading is around 1500 ohms then replacing the control board is
recommended repair. Please get back to me if you have any other questions. Kevin
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
Good Morning friend, that's a great question!
I see that your Frigidaire washer, ATF7000ES0, is displaying an error code of "E41" and you would like assistance in troubleshooting that code. An "E41" typically stands for your main control board thinks the door switch is open. This could be a possible problem with your door switch assembly or main control board. I would recommend performing a reset just in case there is a miscommunication within the board and you can do that by disconnecting power from your washer for roughly ten minutes. If you restore power and continue to see an "E41" I would look over the door switch to make sure it is not damaged. If any electrical components need to be replaced I would suggest having a professional technician out to properly disassemble your washer. This will help you to avoid any future issues. -Matt
Hello phrainer3 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
