How do you take the tractor apart to get to the motor on the john deere turf tractor?
SOURCE: There is no power to
how do you know that the battery is good? have you checked the battery and the charger with a multimeter to make sure that it is showing at least 12 volts, if they are here is a link to the owners manual and that has a schematic of the vehicle in it http://us.pegperego.com/admin/archive/manuals/Turf_english.pdf
SOURCE: I have the John Deere turf Tractor with trailer.
test the battery and charger with a multimeter and make sure that they are showing at least 12 volts
SOURCE: looking for a motor for right rear wheel for a 12
you can order a new one here www.powerwheelsoutlet.com
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
