Question about Clarity (76560) Corded Phone
Why do clarity phone cut off on incoming calls
    Scholar:
    New Friend:
  • 183 Answers
Probably a short in the handset
Posted on Jun 05, 2014
Anonymous
SOURCE:
No dial tone phone jack tested ok phone rings incoming call when you pic up nobody. changed battery still no dial tone or conection on incoming call
This is caused by a failed wireless signal transmitter in the base station or a failed wireless receiver in the handset, these phones are not repaired unless they are under warranty, so all you can do is replace it, this is the #1 PROBLEM WITH ALL CORDLESS PHONES.
Mar 22, 2011 | Clarity C410 Cordless Phone
The red circle around the handpiece is flashing. How do I get it
ditto. same problem. sure wish someone knew the answer to this. its the weekend and this thing is driving me nuts.
Jul 08, 2010 | Clarity C4230 Cordless Phone
Problem with Incoming Calls
yes their is an internal error. she needs to take the phone back where she purchased it. unfortunatly to solve the problem itself one most unlock the phone and fix the buggs in the programming... this is verry hard and requires tramendous skill... It is recomended that you find a new phone or a really talented asian such as myself who can fix the issue onsite with the phone
Feb 23, 2010 | Clarity Ameriphone Dialogue III Text...
Our new 6.0 Caller ID phones have an echo. Can you suggest a remedy? John Chalk johnchalk@hotmail.com
as per jonniewalker from one of his posts:
"it may be due to interference from electronics devices around you since its a cordless phone ,or your phone is not getting a complete connection, could be one cause,Please try these solutions when you experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2) Press ^/vol or vol/v to move the pointer to Clarity Boost, and then select Boost On and "B" appears on the display. To turn Off the Clarity Booster, repeat above step again. check the owners manual for a full description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3. Make a phone call & at the initial stage speak loudly into the mic. Please note: The ECC will learn at the initial stage only, so after these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh registratoin, this can improve the quality of the call. hope this helps pls do let me know"
Feb 11, 2010 | Panasonic (KX-TG1032S) Phone
Echo on my end when someone calls! Please help! Thanks!
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Incoming call cuts off an ongoing phone call
when you are on the phone and you are getting a call does it ask you to swith over or does it do it automatacly.
Mar 04, 2008 | Motorola Mobility RAZR V3
Clarity (76560) Corded Phone Logo
42 people viewed this question
Top Clarity Lands Phones Experts
Marvin
Marvin
Ngoro
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
