I replaced the drain pump, after reassembling the unit spins but wont add water water from house to washer is on.
SOURCE: Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Testimonial: "Thanks for the feedback - good, fast solution. Took the pump apart and verified that there's nothing in there that shouldn't be. Ordering new now. "
SOURCE: Washer will not drain.
access the pump clean out at btm front panel .should be small hose to drain with bucket,remove cap and youll probably find coins /debris that is stopping the pump from draining.The pumps do go bad though...make sure the impellers are not broken.To replace, 3screw 2 hoses and 1 plug,can access from underneath unit.Please rate my answer :)
SOURCE: Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
SOURCE: During the spin cycle the washer makes a loud
If the 'loud noise' water sloshing you should first check that the pump filter isn't blocked. This sometimes stops the pump altogether. Coins, etc..If the noise is metallic it could mean bearings...Check the pump via the small door at floor level...Mind the water inside the machine. You may be able to drain first with a small hose which is inside the pump access door.....Nomess
