Question about Peg Perego John Deere Turf Tractor
How to troubleshoot a alltrax elc motor controler
    Genius:
  • Peg Perego Master
  • 1,508 Answers
I think you posted in the wrong category, this is for the toy tractors
Posted on Aug 18, 2017
Anonymous
SOURCE:
Elc tower of doom building instructions
help.elc.co.uk/resources/mothercare/products/tower_of_darkness_120892
http://help.elc.co.uk/resources/mothercare/products/tower_of_darkness_120892
Let me know if this is the right one or not. If correct, you can just click the "Helpful" menu button. If not, I can search again.
Apr 20, 2018 | Tower Video Game Consoles & Games
How to fix air ride/ electronic levelers on 1999 caddy deville
1st I need to know what is wrong with it. How to fix is just to vague.
Sep 09, 2017 | Cars & Trucks
What fuse controls the inflator,in the air compressor in the 2006 uplander
Two fuse's ELC fuse #2 20 amp ELC fuse # 15 25amp located in the I/P fuse box . Also a relay at the commpressor .
Mar 02, 2017 | 2006 Chevrolet Uplander
Lower rear end of 2002 Park Avenue
Does your Buick have electronic level control (ELC), which utilizes air adjustable shocks. ELC maintains the rear trim height under a wide range of loads. Refer to ELC, as applicable ? Have you changed shocks on the back ?
Jan 18, 2017 | Cars & Trucks
1988 Cadillac Deville. ELC light stays on in dash and drains battery
The light is on because the system fuse was removed, this causes the control module to see a fault. either fix the system or pull the dash and remove the warning bulb.
Oct 25, 2016 | 1988 Cadillac Sedan DeVille
Elc fuse keeps blowing it is from motor being frozan what do you mean by that
ELC is electronic load control and that would be the power seats
Feb 09, 2014 | 1995 Oldsmobile Aurora
My elcs trips when i switch on the water motor. What could be the reason and how can I solve it. please
The water motor is drawing too much power, it has a fault or has got wet inside. The trip cuts the power to protect you and other people from getting electrocuted by the unit. You need to inspect and repair the pump or its controller while the power is off.
Dec 20, 2013 | Refrigerators
Can't find the relay for the electronic level control(elc) for a 1999 cadillac eldorado
1. Locate the automatic level control height sensor under the rear of the vehicle on the rear suspension support. If the back of the car is too low and will not pump up, ground pin B Yellow wire and see if the compressor will come on and the car will raise.
2. If the car does raise when pin B is grounded, check the powers and grounds to the height sensor.
3. If the powers and grounds are OK and the pump does come on and the car raises when pin B is grounded, the height sensor will need to be replaced.
4. If the car is too high and will not come down, ground pin E White wire at the height sensor to see if the car will lower.
5. If the car lowers when the White wire in pin E is grounded, check the powers and grounds to the height sensor.
6. If powers and grounds are OK and the car does lower when pin E is grounded, the height sensor will need to be replaced. Tech Tips: There are two different automatic level control systems for this car; one is without RPO F45 and one is with RPO F45. The system without F45 has an automatic level control height sensor and with F45 the automatic level control compressor is controlled by the continuously variable road sensing suspension module. Tests/Procedures: 1. Using a head lamp as a load, test the ELC height sensor power/grounds.
2. The power feeds are: Orange wire, pin C and a Brown wire, pin D.
3. The ground is pin A, Black wire.
4. Ground the White wire at the height sensor, check that the vent solenoid in the ELC compressor clicks and vents the air from the system. Author: Bill Siegmann
Dec 24, 2012 | 1999 Cadillac Eldorado
???????? ? ???????? ??????? 1995?. ????????? ???? ?????? S036 service ride control, ??? ??? ??????, ??? ?????????
Hello: S036 concerns the road sensing suspension, in this code it tells us the electronic level control (ELC) compressor relay has a short to ground or an open circuit. Fuses to this system (2) one 10 amp in the engine compartment. The other fuse is a 30amp located in the trunk compartment. There is also a relay in the trunk compartment relay center, #2mirco relay center ELC relay "A". I hope this helps you.
Oct 16, 2010 | Cadillac STS Cars & Trucks
Air shock
sounds like the level position sensor
Apr 23, 2009 | 1993 Lexus Ls 400
Peg Perego John Deere Turf Tractor Logo
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
