Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Manually turn on the device (TV, VCR, etc.) to be controlled.
blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
grab your remote there should be an imput button on it if not try the menu u need to select the right input could be aux could be tv 2 tv3 ect.on my tv it says AV i select that and my wii come on there hope i helped!
When a drive is inserted into the USB port, many tv will change to that input. You most likely just need to select the imput button on your remote and change back to the correct imput for what you are looking at.
Try to see if any of these four methods will work. Sanyo TVs 1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote 2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV 3. Press TV/AV or INPUT SELECT on remote 4. Press SETUP, choose TV/AV, switch to AV
You need to get the remote to work to switch on the AV circuit or ther other option is to CROSS/SHORT the processor output to switch on the AV- not recomended.
so get hold of a universal remote and the TV will respond.
check this link:
If the input button on your remote is malfunctioning you can still change the input from the TV. There is a white panel on the bottom front of the TV with 4 buttons. The button on the far left side of that white panel is the input button. Press that to toggle to your inputs.
Regards,
Tony
I'm afraid, if there's no such a button on satellite remote control, the only way is to replace your spoiled remote control with a new one on the electronic part's shop.
