My nokia 7310c start displaying contact service and will not boot
There might be a hardware problem but as well it could be just software related. Try reinstalling the device firmware.
***Prerequsite:
Install Nokia PC Suite for your phone and the drivers if you haven't already done that!
First of all, you'll need a program and the necessary firmware files:
1. Phoenix Service Suite (2012 or any other version. Search for it on Google)
2. Nokia 7310c firmware (RM 379 DP20 3 00 sw 09 40 7310c)
Install Phoenix Service Suite, extract the software (it will auto-extract the necessary files in the right folder, but first it is necessary to install Phoenix).
Now, after staring Phoenix, do the following:
1. Click File > Open product (not Open profile!)
2. Select RM-379 from the list (you can type that in the "Type filter" text box to find it faster)
3. Select the product code (RM-379) from the list and press OK
4. Now press Flashing (at the top menu, where is also File)
5. Check Dead phone USB flashing on the new dialog box that appears.
6. Click the browse button at the Product code input (top section of the new dialog box)
7. Select an option. Any will do. The difference is between regions and languages. But since I don't know from where are you or what language you'll need on your phone, I can't tell you exactly what to choose. But all region files have "English" avaible
8. Press Refurbish. Take out the phone battery, insert the USB cable, then insert the battery. If any dialog pops up, press OK.
8* At this point, DO NOT DISCONNECT THE USB CABLE until the process is finished!
This process should take about 5-10 minutes and after it is finished, the phone should boot up by itself and everything will be fine.
SOURCE: nokia 3315 contact service error
i am the service and i am teling u that the phone shud ve a new firmware
get it to a repairshop and tell them i want to flash my phone they knw what to do after that sentece
SOURCE: nokia 1112 service contact
hi
there seems like a software problem for this nokia service center will help you
SOURCE: contact service displays at starting my nokia
It says Contact service means it locked to Network You need to Unlock it ,yo can get the unlock code from here
Prounlocking.com AND unlock it.
SOURCE: sir, my nokia
Contact service means your mobile is locked with some network , so when you on the mobile it displays as contact service ,
so for this problem you have to unlock your mobile, if you unlock means after that you can use any network at any where in
the world.......
Get the unlock code for your mobile through this site Unlocking4free.com , it has the best instructions and easy methods for getting the code for your mobile from the network lock......
