Write your answer...ihave inverter sukam2.2kvA 36v it is showing overload how I will solve the problem?
There are things you would need to check
1, Does your inverter charge over any other power source?
if no, your inverter input power source has a problem
if yes , then
a, check the input voltage/frequency rating of your inverter then compare it to the output rating of your gen set
i believe there would be a difference between them
use a multimeter tester{ac}
inverters reject strange voltages or high voltage to protect itself from damage
