Dometic Rooftop RV Air Conditioner Logo
A
Anonymous Posted on May 28, 2014
What year is my Duotherm Air conditioner
Serial # 245 31910
1 Related Answer
Anonymous
  • 393 Answers
  • Posted on Nov 16, 2008
SOURCE: Dometic Duotherm air conditioner -Model #57915622
check the thermostat
We are replacing a coleman air condiotoner with a duo therm unit and we are not sure if the wiring is the same
some of the wires from duotherm unit not used may be for external sensors not on the coleman unit. have to look at wiring diagrams to know
How do i bypass the furnace and still use the duotherm 57915.531
Do you have the digital thermostat? You can tell the thermostat you have no furnace. You should be able to disconnect power at the furnace, but the 12v power for the circuit board is provided by the furnace circuit on some systems so make sure you disconnect the wire going to the furnace and leave the wire feeding the circuit board.
2helpful
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
1helpful
My duotherm 59136.521 freezes up quite often. what are the possible problems &solutions?
Make sure the coils and fans are clean.
Unless there has been a leak in the lines this will solve your problem.
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
6helpful
2answers
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
