SOURCE: Front Loader LG Inverter 7.5kg WD-1238C
CL is about the Child Lock which is done by pressing both the buttons together. To release the same do press both the buttons under the display simultaniously.
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
SOURCE: Error Message/OE
This means the water didn't drain out within a 10 minute time period. Check pump trap for debris and clean out. Check drain hose. Check for pump operation during drain period
SOURCE: Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
