1999 Chevrolet Blazer Logo
D
Dean Posted on Jan 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why the engine starts, runs about 5 second, dies and then won't start, if you wait 10 minutes it starts and runs fine, this happens once every few weeks/months or twice in one day, no set pattern. hav
1999 Chevy Blazer 4.3, engine starts, runs about 5 second, dies and then won't start, if you wait 10 minutes it starts and runs fine, this happens once every few weeks/months or twice in one day, no set pattern. have already changed fuel pump, fuel filter and upper intake on top of throttlebody.
jack layton
Level 3:
  • Chevrolet Master 5,569 Answers
  • Posted on Jan 28, 2018
jack layton
Chevrolet Master
Level 3:
Answers
5569
Questions
0
Helped
2394998
Points
20059
I saw what you replaced, didn't see any testing? What testing have you done? Make sure battery has a full charge?
When the problem is ongoing, have a helper crank it, while you check for spark at the plugs. If spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse. Any applicable trouble codes?
If you have the spider fuel system, that system is noted for problems.
5 Related Answers
wickedsteele
AJ Dungan
  • 56 Answers
  • Posted on Aug 09, 2008
SOURCE: I have a 1993 Ford
Yes a fuel filter can cause the problem but I would say it's most likely the fuel pump or fuel pump relay. Can you hear the fuel pump running when you turn on the ignition?
Anonymous
  • 24 Answers
  • Posted on Feb 21, 2009
SOURCE: WON'T KEEP RUNNING
Check the exhaust compression. Remove the O2 sensors before the cataylic converts and see if it improves. If it does that means your cats are cloged and need to be replaced.
Anonymous
  • 1959 Answers
  • Posted on Jun 15, 2009
SOURCE: Dies after running about 2 minutes
It's got all the symptoms of a leak in the fuel line. You may want to start backward at the tank and work your way all the way to the carb to find it but it would be surprising if it was something else. All the best.
Greg
Anonymous
  • 1056 Answers
  • Posted on Aug 13, 2009
SOURCE: 1994 ford ranger interminant fuel pump problems
Loose connection is the problem. It takes petience to find where it is at. Do some wiggling on wires to see where it is.
Jim
  • 1230 Answers
  • Posted on Jun 04, 2010
SOURCE: My focus tdci 1800 ran fine until recently. I was
There are a number of faults I'm aware of with the focus which can cause driveability,cutting out and non start problems.
1 poor earth connections in engine bay, you need to check and clean ALL earth connections in engine bay
2 engine wiring shorts out against EGR valve (but this normally blows fuse F9 (20amp) wiring needs to be repaired and re-routed and secured
3 erratic running and non start (glow plug warning lamp flashes when this fault is present) this is caused by low fuel rail pressure and is expensive to put right you need to check for the following fault codes P0109, P0191, P0251, P1211, P2288, P2291
if one or more of these fault codes are present remove fuel filter and drain contents, inspect for deposits(black with silver particles) if deposits are 11mm you need to remove fuel tank and flush it out.
the following will need to be renewed:
fuel rail, high pressure fuel lines, fuel supply line filter to high pressure pump, fuel return line from high pressure pump to filter, kit protection blanking plugs, kit, leak off pipes, fuel injector clamp bolts, fuel filter, high pressure pump gasket,high pressure pump seal,high pressure fuel pump and timing belt.
I recomed you carry out you diagnosis in this order
Regards
Jim
1helpful
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
1helpful
2answers
Why does engine die right after starting, then you wait 10 minutes and starts and runs good.
check your crank and cam sensors...see if one is not plugged tight in
1helpful
Why my 1999 Chevy Blazer 4.3, engine starts, runs about 5 second, dies and then won't start, if you wait 10 minutes it starts and runs fine, this happens once every few weeks/months or twice in one da
You may be having an intermittent failure with the fuel pressure regulator - checking the fuel pressure when the truck won't start may pinpoint this problem. If the pressure looks OK, this same problem can be caused by the ignition system as well (ignition coil or control module).
95 Ram occasionally wont start
Have you checked fuel pressure before and after cranking the engine ?
Was driving my 1991 Honda Civic two days ago and the check engine light came on, the car lost power but the engine was still on, turned engine off waited a few minutes car started the check engine light...
distributor module.... any recent tune-ups? e.g= cap,rotor,wires,plugs? parts are reasonably priced and labor should be around 1 hour... start there...
92 gmc c2500 turbo diesel. starts then dies after a few seconds.
Sounds like the Pump Mounted Injection Module.. Starts, dies, Starts dies... Not a fun fix.. but atleast it's just under the intake..
2answers
Car sometimes will not start
have the fault codes read
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
