Cars & Trucks Logo
Peter leigh Posted on May 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost my nectar card need replasement please - Cars & Trucks
_-__-___-_
Level 3:
  • Cars & Trucks Master 20,706 Answers
  • Posted on May 28, 2014
_-__-___-_
Level 3:
Answers
20706
Questions
Helped
6788732
Points
57965
Nectar?
what car has nectar?
Got a man truck tga26-410 ,it show a code on the dash EDC00190-12 .when you rev it above 1500 rpm it cut the engine .i have alredy replased 2x sensors on gearbox
I looked through the fault code lists and could not find it, but the EDC indicates lost communication between engine and throttle control
1helpful
2answers
I neede replased spark plugs
change spark plugs with good one,do not change wire some of them ****,fuel filter.no problem do not make one.
Voltage gage drops when i turn the heater on. had to replace the altenator and battery because i literally lost all power. This happened very fast, was fully charged and while i was driving the meter kept...
ok one thing first the thares a few things to check first check to see if thare is a fuse bus buy the batter check all 50amp fuses that is what it sounds to me i dont remimber if that year was fused with the big maxie fuse are if it was a linkeable fuse if it is a linkelbule fuse thin it will be a little harder to find lightly pull on the wires to the b+ on the alt and fallow them a fuseabule link will sterach. most of the ecm are pcm that are replased are not bad so check the fuses first have a 95 that blow both 50 amp fuses and did the same and it happind win i jumped it
I need to replase my water pump on my ford f150 1994 truck.and wondering if i should replase the Dayco hose lower curved.THE HARD PLASTIC PART WITH TWO NIPPLES ON IT THAT GOS BETWEEN THE RADIARTOR HOSE AND...
If it looks brittle I would replace it, with plastic parts if in doubt replace it. if it is a cheap part you could save a lot of time and trouble by replacing it now wile it is apart.
2helpful
THERMOSTATE REPLASEMENT
follow the radiator hose to where it hooks into the top of your engine. Remove the hose and then remove then nipple it was clamped to. Under that nipple will be your thermostat. You will loose antifreeze, approximately 1/2 gallon is wht I lost when I did mine. Make sure you get the right temperature thermostat so it opens and closes when it is supposed to. the temperature will be stamped in the old thermostat.
Fuse and park light problems
#35_it 35
PWR WDWS
30A
• Window master switch • Window switch--front passenger's a 30 amp on rt side of consul
1helpful
I have a problem with my ford escort 1995 it wont start i replase the batery for a new one and i replase tht startmotor but stil wont start can some one help me please
It can only be either the ignition swith or a broken wire between ig switch and starter solenoid, if you take off the plastic bezel around switch I think the starter sol wire is white with red trace,.with a lengh of wire from the pos on battery, touch to starter wire at switch, if it then turns engine over, the fault is switch. If not check other end of starter wire where it connects to starter solenoid on starter
My cooling fans dont work.Ive replased the relay, temp/ems sencer andit still dont work. but when the a/cis on they work plz help
First test the fans themselves. Then if the fans do work, trace your wiring back to find where power is lost.
Are there any service codes?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
