SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
SOURCE: leaking water out of the front freezer side
empty out the freezer and remove the back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
SOURCE: Replacing water line in freezer side door
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
