FRONT LOADING WASHER TYPE WNBM80, WHEN I CLOSE DOOR AND TUN ON E27 APPARS AND BEEPS
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
SOURCE: front load bosch wont start.
Hi If the door is completely closed and nothing is bad then it means
the control board should be replaced. Hope this helps...please post back for
further assistance. Daniel
A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock. If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
