SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
SOURCE: My kids gator wont go in reverse, and it makes a
ours did the same thing so I replaced the gearbox in it. I bought it at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-gearboxes-and-motors.html
The reverse problem might be a bad switch, but you can contact the service center at 1.801.655.0800, they always help me out if I don't know what is wrong.
hope this helps
SOURCE: REVERSE WENT OUT OF OUR KIDS JOHN DEERE GATOR.
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath you can order a new one here www.powerwheelsoutlet.com
SOURCE: I need a service and parts manual for a gator XUV
You can find the manual here: http://www.fixya.com/support/p11699234-peg_perego_john_deere_gator_xuv_igod0063/usermanual-6E56E71-pdf
Page 7 has a replacement parts diagram with the corresponding part numbers.
