SOURCE: loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
SOURCE: how do you install a shift spring on a craftsman
Are you talking about being able to stretch it? I made a tool out of a coat hanger with a small hook formed at the end; the other end fed thru a hole in the center of an old pull start handle (or something similar), and bent over so it doesn't pull out.
SOURCE: 171/2 hp craftsman dual blade...one blade won't turn what's up?
your bearings out on spindle housing above the blade.
SOURCE: Craftsman zero turn runs but blades won't engage.
if got elect. pto/ and clutch,could have a wire connector come loose
