If your lights for the battery and alternator are on it could very well mean that either your battery is no good or that your alternator stopped charging. If it has stopped charging, you have what's left in the battery to get yourself to the repair shop before you're on the side of the road.
well you mait want to check the Car generator is is working or not beacause if is not you can still buy new battery and they still will not charge and the will day and the light will be off
I had the same problem in me 2004 cdi e270. Check the voltage going to the battery when the car engine is on. Stedy charge of 12v should be going in to the battery, if the voltage is volitale say between 11v to 14v then it your Regulator (which is attached to the backend of the alternator). You need to change alternator and then unplug all the batteries over night and re plug them back again. The problem should go away.
This is normally a low voltage from the alternator condition. Hook a voltmeter to the battery and note the reading. Should be 11.6vdc to 12.2vdc. Start the car, after a minute or so it should be around 13 to 14 vdc., if not then the alternator may be bad
MERCEDES C200 Kompressor 2001. battery alternator visit workshop is flashing on trip computer. i have replaced alternator. everything is ok. battery getting charge... i cant see any thing wrong so why workshop flashing?? maybe something wrong with new alternator 4 exampel voltage sensor??
"Check engine light" EMISSIONS WORKSHOP! Do you want to shut it off???
After reading all of the negative comments and how much money Passat owners have spent due to this manufacturer's problem, I am going to save the day and save you $$$ by showing you how to "reset" the diagnostic computer which makes the "emissions workshop-check engine light come on! (This is the same thing the VW dealer will charge you hundreds of dollars to do.) To turn off the "Check Engine" (Emissions Workshop) light, simply follow these 5 basic steps:
1. Pop open the hood.
2. Insert the key in the ignition and turn without starting the engine until all of the dash indicators light and warning tones sound.
3. With the key still in the ignition, use a 10mm wrench or socket to loosen and completely disconnect the negative (-) battery cable from the battery. Wait about 60 seconds before reconnecting.
4. Re-connect and tighten the negative (-) cable to the battery and close the hood.
5. Start the engine. THE "CHECK ENGINE" LIGHT HAS GONE OUT!
If the light stays on, then there really is a problem. If it has turned off, be glad, but don't be surprised to see it come on again in a few weeks. If it comes on again, simply follow steps 1-5. Remember... This quick repair is for those who just can't stand looking at this light or afford to visit VW every time this light comes on. If you feel the need to service the vehicle, service the vehicle. I hope this has made your "NIGHTMARE" a little easier!!!
