Model # PYE4500AYV Serial # 11168132AV. The unit just quit working. It has no power and the light inside will not even come on. The out was checked and was good. The cord was checked with an OHM meter and found to be good. What's my next step?
Lee
Are getting power to section switch, any internal fuses. also check the safety switch on the door.
i forgot one thing and that is the start button. make sure that there is power there. when you push the safety switch in you should hear a faint click in the upper counsel if you do then the power is getting there, you can also check motor and see if got power there. some where the power is being broken.
Hello friend, thanks for your post!
I understand that your Frigidaire dryer is beeping and flashing lights. To reset your dryer you should disconnect power, by unplugging it or flipping the household circuit breaker, for roughly ten minutes. Which lights are blinking on your display panel? It could be providing you an error code.
If the reset does not help correct the issue, could you please provide me with your model number? Typically you can locate the serial tag (which lists your model number) on the door frame of your dryer. If you need further assistance please reconnect with me. -Matt
I didn't see any internal fuses. I took the switch off the door and checked with an OHM meter and everything checked OK. I am having a hard time checking the timer. It has so many wires, I don't know if I am checking it right. IF THE TIMER IS BAD, WILL EVERYTHING INCLUDING THE LIGHT NOT WORK? I checked the heating element and it also checked OK.
