Question about Inverter KEB COMBIVERT F5
E.PU error the error comes up randomly after 2 minutes or 10 minutes, it remains displayed fot just 1 second. ower supply already checked (407ACV ok).
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Inverter Expert
  • 120 Answers
E.PU is a general power stage failure.
Without knowing the part number of the actual inverter with the problem it is difficult to speculate what the actual problem is.
One thing to do is to check if the fan is operating. Some of the older F5 inverters utilized a feedback loop so that the inverter could tell if the fan was functioning properly. If the fan was not functioning the inverter would trip into E.PU.
Posted on Jun 04, 2014
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
How do i fix error code c3823 for bizhub 223
Hi found this top is fault. .bottom is remedy good luck
Jun 01, 2016 | Konica Minolta Bizhub 223 Copier
Model 451. What is error code 3B02?
The power supply that controls the fuser (The Hot part) unit is causing that code.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
DO THIS ONCE IF IT COMES BACK REPLACE THE FUSER POWER SUPPLY OR A FIRE CAN START THAT WILL RUIN A PERFECTLY GOOD DAY!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 23, 2016 | Konica Minolta bizhub Office Equipment &...
1994 Mazda PU Truck sometimes won't start if shutoff for 5-10 minutes.. Several tries later, it will start. spark seems ok, it gets enough fuel for a second, but then poops out. fuel pump shuto
Well there is no shutoff relay, but there is a fuel pump relay that powers the pump.
I would check it first. The computer grounds the relay for 3 seconds when you crank the engine to boost fuel pressure. Once the engine starts the pump is powered only if you have oil pressure.
Apr 12, 2013 | Cars & Trucks
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Hp photosmart 3210 error oxc18a0206
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 12, 2010 | HP Photosmart 3210 Printer
My hp photosmart C7180 All in one comes up with the error code of oxc18a0506 when I turn it on.
Hi there
Solution 1:
Solution 2:
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
C8180 Error Oxc18a0001
Hi there
Solution 1:
Solution 2:
Oct 15, 2009 | HP Photosmart C8180 InkJet Printer
Printer error Oxc18a0001
Hi there
Solution 1:
Solution 2:
Jul 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
Apr 29, 2009 | Uniden Cordless Phone
Inverter KEB COMBIVERT F5 Logo
331 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Larry Ng
Larry Ng
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
