Battery will not go until audible click the manual says. First time trying to attach to trimmer. Is it harder the first time to attach? Any help would be great
Generally all portable tool batteries slide into position until a click is heard alerting us that it is locked in position & just wont come falling out in use, look @ the manually closely & follow the steps ( you'll get it! ALSO note there will also be a way to release the battery once you have charge it......Good luck :)
SOURCE: BLACK AND DECKER CST 1000
see www.dewaltservicenet.com look for find it now icon then enter the model #
SOURCE: Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
SOURCE: How to wind string around the bobbin
The manual is available on line if you do not have your hard copy OR you could purchase a spool already loaded and ready to go.
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
