Sony Ericsson K800i Cellular Phone Logo
Posted on Jun 24, 2009
White Screen I have a white screen and can't get rid of it. I tried taking the batterie out and it still had a white screen and I shut it off and on a lot but still a white screen. What do I do???
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5708
Points
Ma k800i has a white screen and i thik its a software problem
2answers
My screen is white
if it doesn't turn off you need to hold the power button 8 seconds
shut the console.
remove the game ship
using a tooth pick, press a small button inside the slot
Now power on and it should be fixed.
Still need help, search in You tube for
How to get rid of the dsi white screen of death
check the screen display unit would have been damaged if so
you will be compepelled to replace it do not do it yourself take it to a
reliable repairer
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 • Cell Phones
Krzr k1 the screen went white and it shut down.( continuesly )
There is a problem with motorola phones .Data cable between screen and main board use to brake by the flip top screens hindge.Hopefully it is not your problem,if it is then only in service they can fix it by replacing this cable.If it is a software problem then you can try to solve it by yourself.It may work if the software is faulty on the phone.Just follow the link below.
http://motohell.com/
K880i white flashing screen
White Screen Of Death. Quite common on Sony Ericsson phones. My K800i does it every time its battery shuts off while it's on (so I try to make sure it doesn't). You need to (google terms) reflash sony ericsson phone Maybe also first backup GDFS The photos, except those on the memory card, and other stuff will be lost, I'm afraid. But good news is that your contact list can likely be saved by backing up the GDFS.
V3c RAZR white screen at shut off only
can you do formatting? format it now, their is some program have deleted in your phone. i can format a cellphone, but in nokia. maybe i will find a way to solve your very little problem. i have a problem too! can you solve it? my problem is your phone.
4helpful
3answers
My samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
3answers
Screen is white
just press *3call and on offswitch altogether till u get a formaating message
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
