Light doesn't work
- Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
- Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
- Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
- Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
- Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
- Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
