Tube split and needs to be replace
SOURCE: no water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
SOURCE: water dispenser leaking
there seems to be a problem with the drain house and the pump... did u chk out both the components properly... do a thorough chech on it... and get back here... thank u
SOURCE: Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
SOURCE: Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: How do I replace the
Hello, Ice makers
and water dispensers are convenient to have on your refrigerator, but
can also cause a lot of aggravation if they are not functioning
properly. If your water valves are not defective and you are still
experiencing water or ice delays, you may have a clog in your
refrigerator hose line.
Instructions and material needed to fix it up.
Good Luck and thanks for using fixya.
For water not dispensing
problem:----------
There possibility is ice blockage in the
water fill tube. There is a tube from which the water runs and enters the water
dispenser. If this tube is blocked then water will not flow, when you depress
the water dispenser paddle. The tube needs to be defrosted, by using hair
dryer. This procedure melts the ice collected in
the tube and water starts running again. But if water fill
tube is completely clear and no ice blockage or any other blockage. Then other
possibility is water valve .This water valve is for letting the water. The main
water valve the back of the fridge section. This main valve lets the water
enter the refrigerator.This water valve is a twin valve.This valve has two
tubes in it.One for water dispenser and one for ice maker chamber.The one side
of valve is working, but other side of the valve is not working.The valve is
got stuck in one position, so ice maker side is working, but water dispenser
side is not working.--------
The valve is not a costly part
and can be easily replaced.-----------------
then You can get
required parts from online sites like:
--- www.repairclinic.com or from searspartsdirect online site. ----------- This should
help. Thanks.Helpmech.
For water not dispensing problem:----------
There possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the water dispenser. If this tube is blocked then water will not flow, when you depress the water dispenser paddle. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve .This water valve is for letting the water. The main water valve the back of the fridge section. This main valve lets the water enter the refrigerator.This water valve is a twin valve.This valve has two tubes in it.One for water dispenser and one for ice maker chamber.The one side of valve is working, but other side of the valve is not working.The valve is got stuck in one position, so ice maker side is working, but water dispenser side is not working.--------
The valve is not a costly part and can be easily replaced.-----------------
then You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
problem:----------
You can get
--- www.repairclinic.com or from searspartsdirect online site. ----------- This should help.
Thanks.Helpmech.
