-Never know. It could happened any time.
-If you still have receipt then call the factory and get it fix for you.
Most appliance come with 1 year warrantee. So you better hurry before 1 year.
It says manufactured 5-00
The 5 is fifth month which is May and 00 is the year 2000
It was made in May of 2000.
I think by looking at the model number it is 13 cu ft.
http://www.master-bilt.com/comdir/direct.htm
go to this site. It has info that you can contact them and just give them your model and serial and they can tell you. It's just that easy.
Hope it helps.
Good day, Somewhat handicapped not knowing if it's a conventional freezer or frost free. 1. If it's frost free check to see if the fan motor is running in the freezer compartment. 2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
you should def have a 5 year warr on your compressor( all your sealed system parts) , youll need a factory authorized company, to come ck out so if it is a sealed system repair they will honor y our warr. dont know how it works where you are but,theres got to be 12 companies just in my area willing to do that
YOU COULD GO TO THE AUTO ZONE AND BUY A TAP VALVE AND FREON 134A CHARGE IT THROUGH THE LOW SIDE SHOULD READ 5 AND HIGH 150 USE 134A. IT MIGHT WORK FOR A FEW MONTHS TO A YEAR IF NOT LONGER BUT YES IT HAS A LEAK THE CONDENSOR IS BUILTIN AND MADE OUT OF STEEL AND IT RUST THROUGH OUT THE YEARS THEY SHOULD OF USED COPPER NOT STEEL
