Question about U-Line Refrigerators
Why is 2015RS-01 running...light on...but not cooling?
My undermount 2015RS fridge stopped cooling. Light is on. Motor running. But HOT inside.
    New Friend:
  • 14 Answers
Could be out of gas.
could also be a bad evaporator (inside ) fan.
is the back wall of the freezer icy and everything else warm
Posted on Jun 05, 2014
6ya staff
SOURCE:
the dr
joey shearer
  • 447 Answers
SOURCE: Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Posted on Sep 29, 2007
Anonymous
SOURCE: GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Posted on Jul 26, 2008
Anonymous
SOURCE: Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Feb 28, 2009
Anonymous
  • 102 Answers
SOURCE: Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Posted on Apr 11, 2009
Anonymous
  • 212 Answers
SOURCE: Freezer light flashing
if you have ice built up on rear wall of freezer section then your unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow over to the fresh food side.
Posted on Jun 24, 2009
Why is 2015RS-01 motor running...light on...but not cooling at all?
Hi Liz,
I am wondering what motor you hear? I think you might hear the condenser fan motor if anything. The two things that I have seen fail on u-line products are condenser fan motors and/or cold controls. Not much to the unit at all. So I am going to assume you hear the fan motor in question, I would check voltage to the compressor and see why it not running first. Get back to me when you now more information and I can help you more. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
May 23, 2014 | U-Line Refrigerators
Fridge stopped working light on motor not running
Robert,
Need more info. I am unaware of a "light on the motor". There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. Normally none of these have a light. If you are referring to the light inside the box that turns on with opening the door AND the frig is not cooling, we must go to the very start. 1. Verify power at outlet.
2. Do you see (or inside the box- hear) the two fans running. 3. Is the compressor smoothly vibrating?
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Smeg FR158SE 1 Compact Refrigerator
Stop 2min and run for 2min, stop 2min and run for
your motor thermal safety relay is protecting the motor from burning out
this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again
check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
Jul 24, 2010 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
My GE fridge (gss25jemaww) stopped cooling. The light still goes on and off like normal, and the motor works, but the fridge and freezer do not cool anymore. Everything inside thawed.
This tell me the compressor is not running. I would like you to pull the fridge away from wall unplug and remove the cover over the compressor. Feel top of compressor and if too hot to hold hand there keep unplugged and let me know. There are some test I would like you or someone skilled with a test meter to do to eliminate the compressor start components and motherboard. Sea Breeze
Jan 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator stopped cooling, but I still have power and lights, however, my digital cooling settings are no longer lit. Is it possible my board is bad and how do I go about fixing this problem, or can...
check back side of your fridge touch the motor compressor running or not if not running check the electronics board and make voltage check from electronics board to motor compressor. if the compressor running touch the one side of copper tube if have hot one side. if have hot your freon ok check the cooling fan inside the freezer side ok good lock
Jan 01, 2010 | Refrigerators
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My U line model 2015rs just quit working. Power
Thermostat is more than likely bad. Nothing runs but light is on
Sep 28, 2009 | U-Line 15R Compact Refrigerator
My cda554 beko refrigerator not cooling
hello there.........is the refrigerator motor running...(not the fan)...if this is running...pull the fridge out for access.....check the smallest diameter pipe on the compressor for heat.(not the small charging stub which goes nowhere)...in normal operation this small pipe should be quite warm to hot.....if its not it is possibly due to an internal gas leak....fridge motor will run but not cool the fridge.....if the motor isnt running but the internal fridge light is on when you oen the door it is possible the thermostat (temp control) needs replacing
Regards Sir Galahad
Jun 22, 2009 | Frigidaire FRS26R4A Side by Side...
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Refrigerators Logo
89 people viewed this question
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
