The new augur motor is not being energized. Check the circuitry that feeds it power and you will find the source of the issue.
Testimonial: "https://www.youtube.com/watch?v=p9GjSqi6eY4 It was exactly what was wrong. In the morning will take it apart and fix.. Thanks"
Check the ice storage container. The
ice dispenser will not dispense ice until the first supply ice has dropped into
the ice storage container.Remove excess ice from the back of the
ice container. Make sure ice cubes are not jammed between the ice maker and the
back of the ice container.
The
auger won't engage or turn
to dispense ice.Remove the ice bucket and with a hair dryer warm up
the inside where the fork is that turns the auger in the bucket and try it and
if this does not help then you will have to replace the auger motor ,, chances
are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required
parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks.
Helpmech.
