SOURCE: Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
SOURCE: ge profile side by side 'fridge
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
SOURCE: fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978
Look at following areas for the model number
SOURCE: fan is running, fridge and freezer not cold
I have a Westinghouse side by side refrig/freezer that the compressor will run but will not cool or freeze. Do you have any suggestions?
