SOURCE: Replacing traction drive belt for John Deere L118
Actually this is a fairly easy looking one to replace. If you go to John Deere parts and do a search for your tractor, in the parts listing it gives a pretty clear picture of the routing and configuration of the belt as it should go on, you might want to print it out to have nearby while you are working on it. You will need to remove the mowing deck to get at it and possibly some large blocks to elevate the tractor to give yourself room to work.
Look closely at the old belt if it is still on the tractor to get an idea what is involved BEFORE you start, comparing it with the picture. You will need to loosen and move or remove the belt guards and do be careful of the nylon fan on top of your transaxle
SOURCE: John Deere ride on mower L100 17 hp.
my ride on runs well for 5 miutes then just stops wait a few minutes starts right up but does this over and over some help please
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
SOURCE: i need a diagram that
hi there pauly46 here
type f725 in the search box - under j/d cataloue
here is web site adress to go to that page
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=f725
select f725 ,select sectional index , select mower deck and lift linkage,select mower drive belts sheaves and spindles ,
then a window with deck parts and diagram will appear
print this off
it will give a good idea of belt routing for deck
take a look and hope it helps
cheers pauly46
