SOURCE: When i try to run, it stops and then goes. Its
hi it seems like the belt on the motor has either slipprd or needs to be tightened, i had the same problem. i just tightened the belt on the motor and its working fine!
SOURCE: my proform crosswalk 590
Have you lubricated the walking belt & deck?? Are the deck and/or belt worn out and require replacing??
Check the deck for damage and wear, check the belt (feel the outer edge and then the center. Is the center fuzzy??)
If the deck and belt are good, lubricate them and try again.
Is the belt to tight??
Are you using an extension cord??
The machine is drawing too much current, usually deck & belt or defective motor will cause your breaker to go..
SOURCE: proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
