The washer will fill, run, spin and drain (a complete cycle) when it is empty but will not run when it has a load in it. It will try to run but then flashes ND on the screen. I checked both hoses, to and from the pump and they are not clogged. I ran the pump with no hose on it and can hear/feel it working (can feel air blowing out the outlet side)
Hi Ben
I see you have posted on this before , I think you may have done this already judging from your post , but have you checked the filter on the drain pump? also when you run a cycle empty, is it filling and draining the water correctly , or is there water left in the machine , and last is the drain hose high enough to make sure that there is not a "syphoning" effect taking place as in when it fills with water it drains at the same time , just a thought let me know.
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
I will try that when I get home. the model number of the washer is NFW7200TW if that helps add any info.
Took off and cleaned the drawn hose, took the hose off the drum and feltl inside all the way around and there is nothing in there. Took the pump off and cleaned it up. Put it all back together and and it ran fine through 2 rinse and spin cycles. Ran through quick wash and it gave me a code nd agin half way through. Shut the machine off for about 5 min restarted on rinse and spin and it ran all the way through. What the french?
