I expect the design of your new chainsaw will be similar to many small engined tools where owners often discover they need an extra hand.
Usually the throttle is opened (trigger pulled) and then the trigger lock is pressed and the trigger released. The lock will hold the throttle partway open; freeing both hands to hold the tool steady and pull the starter. The partway open throttle makes starting easier and once started, the engine will run fast aiding a quick warmup and less chance of dying or fading.
Once the engine has warmed enough so the choke can be disengaged, a quick squeeze of the trigger will allow the trigger lock to disengage...
Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
Be sure the exhaust port is not clogged. Be sure the choke lever is in the run position. Also you might try letting it warm up half choked before you "pull the trigger"
Sounds like 2 things-either your not letting the engine warm up to near operating temps before fully disenguaging the choke or the run jet (in the carb) is gummed -up.Old gas has the same effect. A teaspoon of Berrymans Chemtool added to afull tank of gas will clear out the gummy **** in the carb. When I start my 10 year old weedeater I pay attention to how cold it is to start with. When it's below 65 degrees I have to run it at 1/2 choke for a couple of minutes provided-that the air/fuel adjustment screw is at the optimal adjustment(per owners manual instructions).
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
You need to put it in full choke. If it is in full choke and still won't start, try pulling the trigger a bit. once you have it started in full choke, back it down to half choke and hold down the trigger until it catches. Once it catches take the choke off entirely WITHOUT removing your finger from the trigger.
