SOURCE: I have a 2510 John
Hi, I'm David .Hope i can give you some help.
First of all I beleive if you Make Sure you Don't Hahave the Clutches Backwards,Its Easy to do this.To line them Up your going to need a Helper,Trying this by your self will were you out.
Check to make sure The Splines are the Same as the Old Clutches.Includind the amount of Teeth in Each Clutch Have Got to be the Same.
Second make sure you have Plenty of Slack in your Clutch Adjustments.Remember you just removed a Work set of Clutches.So you'll need to Back off The Clutch Adjustments.
To give you plenty of Slack.You might also want to See if your Dealer Has a Pilot Tool or Clutch Alingment Tool to Help you .
Sir I hope i've Helped you.
Please let me Know by Voting on The Quality of my Solutiuons. Thank You:
