Question edited for clarity.
Question moved from Elna Sewing Machines
No one has reported this issues, so there are no known fixes. The system is simple, just a hinge with a spring to counterbalance some of the weight. Look for something out of place or binding at the hinge area, perhaps the pivot pin is dislodged.
This sounds more like the motor is bound up. The other solutions are, check for thread wrapped around moving parts, any belts that may have become displaced.
Turn the power switch to the off position and use the pedal. I suspect you only use the L and H for winding the bobbin automatically and the machine only has one speed.
did you get the machine from a dealor or individual? not all machines put their needles in the same way. do you have a manual? it sounds like the machine needs to be cleaned (serviced). the oil is probably thickened, and will freeze the machine up. make sure the needle is in correctly, and threaded correctly. bobbin too.
