Works occasionally
SOURCE: dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
SOURCE: INSIGNIA DVD Recorder/VHS Recorder NS-1DRVCR
yes it has to be finilized use very compatable media by memorex DVD-R this wil solve everyones problems
SOURCE: insignia ns-dvd1-a
Also having same problem. Code bove is not working. DVD player may have been updated with new code.
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
SOURCE: insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
