SOURCE: Swisher zero turn. replaced battery key switch won't start
Hi..my name is Keith...and it could be a blown inline fuse or one of the safety switches has failed...and if you troubleshoot these..and everything is fine..write me back and we will dig further into the electricial system
SOURCE: i need a belt diagram for a 60 inch Swisher lawn
There is a good repair manual here:
http://www.manualnguide.com/dl/3425/
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
SOURCE: I have a swisher ride king mower that keeps
I have been told if the parking brake is engaged and you try to drive the mower it will instantly put a burn spot on the belt. I hope this helps.
SOURCE: how can I put more tension on the belt of my 44 inch swisher trail mower
I would try replacing the spring
Hello, I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
My name is Dane and I am going to try to help you solve your problem. I've done a little research on this mower and I believe your problem could be your drive belt. Swisher Part number 6046 which is a 47" belt. I have found your operators manual at the following link:
http://www.swisherinc.com/manuals/PDF/ZT/ZT2560.pdf
I didn't know if you had the 06-046 model or the 07-152, but the belts are the same for each. Once a belt becomes worn they will give the symptoms you are discribing. You can replace the belt per this manual and all should be well.
