HP Pavilion dv9000z Notebook Logo
A
Anonymous Posted on May 16, 2014
How do i replace screen for hp notebook ze5375us
The screen shows white colour only after booting but i can hear the speakers as the computer boots.
matsak spiros
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • HP Expert 147 Answers
  • Posted on Apr 16, 2017
matsak spiros
HP Expert
Level 2:
New Friend:
Cheetah:
Answers
147
Questions
0
Helped
32267
Points
493
How you confirm that yoy have problem with screen and not with gpu (graphics card) of the laptop. If you connect the notebook with external monitor you get picture or still white colour.
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on Mar 16, 2008
SOURCE: hp pavilion ze4300 white screen on boot
It is likely to be either a faulty screen or a faulty screen cable. As the backlight is working and only the data is missing.
Anonymous
  • 2110 Answers
  • Posted on Dec 11, 2008
SOURCE: i am having hp pavilion dv2000 notebook pc.
try to go into BIOS by pressing F2 or Del while booting...
then change boot device order as 1st boot device as Hard disk
Anonymous
  • Posted on May 27, 2009
SOURCE: Hp pavilion dv9000 wont boot,coloured lines appear no bootscreen
This is caused by burn out of the Nvidia graphics chip on the motherboard. You need a new motherboard. This is due to a design flaw (the subject of a class action against HP in the USA). I have had two motherboards fail on me in this way so far - do not expect any worthwhile support from the HP "support" people they are all in India and can hardly communicate outside of their simple repetative scripts. Its impossible to escape them - I tried communicating with head office but all you get is contact details back to the incomprehensible Indian call centre. I strongly recommend against ever purchasing from HP again.
Anonymous
  • 4 Answers
  • Posted on Sep 10, 2009
SOURCE: HP PAVILION DV9000 COMPUTER STARTS BOOTING UP AND THEN STOPS.
here is the only solution available on net:
give it a try:
http://amritbera.blogspot.com/2009/09/solved-hp-infinite-restarts.html
enjoy..
Anonymous
  • 12 Answers
  • Posted on Jul 23, 2010
SOURCE: hp pavilion dv2000 notebook will not boot up
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
How do i fix my hp laptop screen displaying white
1) Check if the laptop is able to be shown on an external monitor. If it shows up, then it is a screen issue on the laptop.
OR
2) But if it doesn't show up on the external monitor, then its video problem on the laptop motherboard. The video chip is part of the laptop board, it solders on. So its not user replaceable like how it is on a desktop.
Desktop video, if the on board/discrete card doesn't work, then you simply get a video card and plug that into the computer. Install the new driver after removing the existing driver (on board or old video card) and then your good to go.
1helpful
2answers
I have an all white screen when I. start my computer
From the descrition this is a motherboard problem, Hp is well known for issues of this sort. Hook a spare monitor to the video output usually on the back, if picture okay! there is a problem with the new screen. But if both show the same symptoms it is the Video Graphics Card normally built into the motherboard. If that is the case a motherboard replacement will be expensive.
PB Minos GP2W screen has coloured lines fades white then black
Most likely it's graphic card problem, but also may be monitor itself. First, check the signal by connecting to TV (if yours has a PC input), then replace card if that shows the same.
When I turn on my monitor, its goes straight to a
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Technique .
1helpful
2answers
Black screen with HP logo in center of screen. I checked to make sure my ram strips were seated tightly.
Can you enter the bios when its first switched on? ( press F2 or F10?)
Remove power, take the battery out, wait for 5minutes then try and startup again with only mainspower. If that works, shut down replace battery and power and startup.
If none of that works sounds like faulty mainboard. You could also try and and boot from a PE disk, like Bart PE or Knoppix if you can download and burn form another PC. This way you'll also be able to get your files off easily if it is kaput.
2answers
Laptop Screen faded white
There are a couple of possibilities.
1. A cable has come loose inside the computer4.gif.
2. A cable has become defective.
3. The LCD is defective.
If you wiggle the LCD back and forth and you can get the picture to work again intermittently then answers 1 & 2 above would be more likely.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
