Kenmore 42822 Front Load Washer Logo
A
Anonymous Posted on May 16, 2014
110 42824 clothes are very wet - Kenmore 42822 Front Load Washer
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
3answers
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Thor laundry system won't dry clothes I have a thor no venting washer/dryer combo machine, that has been working fine for years. Suddenly it is not drying clothes and instead, clothes are soaking wet...
I am having the same problem on a WD9900A. The wash cycle works great. Spins fast and clothes are completely rung out. Dryer cycle heats up well. Fluffs and heats cloths. At some point during dry cycle water is injected on clothes and they end up sopping wet; much wetter than after wash. Filter is clear. Outlet pipe clear and functions well. Possible problem with dryer timer? Or washer timing kicking back on?
2helpful
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
1helpful
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
1helpful
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Alexander
vince
