Bottem freezer is cold , top refrigerator is not ,cleaned out from under it , there seemed to be a lot of dust.
In the back of the refrigerator, there should be a vent. Put your hand over it and see if air is coming out. This will tell you if the fan the other poster mentioned is working. If no air is moving then either the fan is bad or the channel is plugged. If only a small amount of air is moving through, open the freezer door and check the air flow again. If the flow got much better, then the return channel is plugged. Try these steps, and if they help post back and I will tell you what to do next.
It may be the fan motor that in the freezer that blow into the cooler cabinetmight be out.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
