If you cannot find it anymore, you may want to find replacement for it.
Sanyo Remote Control eBay
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view, will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops or online by Ebay or Alibaba.com.
SOURCE: need a remote code my new sanyo tv to go with
I went through all the Sanyo TV codes and then started entering in groups of 10. The U-verse offered 1103 i did 1100 to 1110 and it worked with 1107. Unfortunately at&T said you have to check the manufacturer which doesn't list universal codes. I was lucky on the Sanyo 18.5" LCD from Walmart using 1107!
SOURCE: Sanyo TV DP42647 No picture or sound, remote does nothing
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
SOURCE: I have lost the remote to my sanyo DP32746 32 inch
just go to sanyo service center to buy a new remote control, to fix your problem
SOURCE: I have a CLT2054 but i missed the power cable
I found an AC adapter for the Sanyo CLT2054 on ebay that works GREAT!!
The ebay dealer is cenyglobal, specify "Sanyo-Right-4Pin-12V5A"
AC Adapter. Price is ONLY $14.99 + $4.99 shipping.
The problem is that the CLT2054 TV has "2" different power plug hookups.
When you look at the 4-pin connector with the flat side UP, for my TV, 12V is on the RIGHT 2 pins. On the other versions12V is on the TOP 2 pins.
HOPE THIS HELPS!!
SOURCE: Trying to access input function on my Sanyo flat panel screen with sony DVD remote
Its 50-50 at best that it will program or work.
Another option is take the bad remote to a repair shop--where I work we fix most of them and usually under 20 dollars.
