Keep getting error codes F2 E0 and E0 n 0F2. what could it be, when the oven will work but cut off around 350 degrees.
SOURCE: my RBS275 oven has E0 F2 error code
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#
SOURCE: Whirlpool oven RBS245PDB2 - Was getting the E3 F2
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$!$
SOURCE: Error code E0 F2. Now
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock).
SOURCE: How to fix the F2 error code that shuts down my Whirlpool oven?
You have a bad oven control board and temperature sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
