Hi there. My speakers volume knob has stopped working and so has the remote. The volume is stuck at one level and it won't increase or decrease. Any ideas on how this can be fixed? I love these speakers and would hate to have to replace them. Thanks. Mjp
SOURCE: Logitech Z2300 rustling sound on volume knob movement
I would definately not open up the wired remote. As for the rustling sound, I had the same problem with my set (only with a hissing sound instead of rustling). Make sure the output on your computer is all the way up, as well as the volume on whatever media player you are using. That eliminated the sound for me, but it might be a different problem alltogether.
SOURCE: popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
SOURCE: I have just bought
try swapping the speakers
around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
or you might have to clean
the dust from your computer dust causes static which causes your computer to
overheat and all sorts of problems
be sure to wear an anti
static earth strap before touching anything inside your computer try
cleaning your computer of dust using a fine air blower from a compressor making
VERY sure that there is no MOISTURE in the air line specifically around the CPU
central processing unit and your SOUND CARD dust causes static to build up in a
computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
SOURCE: Rear speakers' volume of X-540
In order to do this, your computer must be able to support 5.1 systems! Seeing as how a person wouldn't buy this particular set of speakers without knowing that information, I'm guessing you have a bit of knowledge under your belt. You need to go into your audio device settings on your computer and you should have the ability to tweak the settings of the rear speakers from your audio controller panel. I myself have the EAX which allows access to adjusting the speakers volumes based on distance from the listener!
