I have a three year old 2015-WCOL that stopped cooling. Light works, condenser reg vacuumed and the door seals correctly. However, when I turn the dial to power it on, the compressor runs and cools to a certain point, but then shuts off and does not come on again to maintain the temperature. The only way I can get it to power up again is to turn the unit off, let it sit for a few minutes, and then turn it back on. It repeats the same cycle each time. The compressor will run for a short time, but again not enough to cool to proper temp. Control panel? Thermostat?
SOURCE: cools at start up....then gets warm..compressor is warm.
I would need to know the model of this. However if the condenser fan is Not runing then the problem is that. If it is then it could be the sealed system and you will need a tech to check it out.
SOURCE: Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
SOURCE: My U line model 2015rs just quit working. Power
Thermostat is more than likely bad. Nothing runs but light is on
