Frigidaire Affinity ATF7000E Front Load Washer Logo
A
Anonymous Posted on May 10, 2014
My Frigdaine Affinity FAFS4272LAO dose not fill all the way
Model FAFS4272LAO. How do I replace the vent latch?
Try here: You can see the schematics, and manual here: http://www.searspartsdirect.com/frigidaire-parts-washer-parts/model-FAFS4272LA0/1428/0153200.html?searchType=modelSearch&prst=&q=FAFS4272LAO&searchTerm=FAFS4272LA0&shdPart=
1helpful
FRIGIDARIE AFFINITY WILL NOT FILL UP WITH WATER ALLTHE WAY
Hello Carl Kjonaas - Is the house valve(s) fully turn on? Typically when water is not filling completely, the washer could possibly have a faulty switch that does not allow the valve inside to turn or a kinked fill hose. Other possibilities of more potential serious issues are water valve faults, faulty control board, pressure switch or wiring failure. If I was in your position, I will personally consult a professional to move forward accurately and assist with the repairs.
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
My washer is filling with water when i'm not using the machine. I read somewhere abot some wort of inlet vavle needing to be replaced?
Unplug the machine. If it still fills with water then mechanically the water valve has failed. If it don't fill while being unplugged then something in the control is doing it, might be the main control is bad. Who knows?
Affinity Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Frigidaire Affinity washer won't fill with water, and after a few minutes of spinning with no water, flashes an EF0 code, or sometimes an E10 code. I tried unplugging the machine to reset it, but get the...
My affinity atf8000fs1 won't fill with water. I replaced the inlet valve, pressure valve, Main board and power board and door switch. Same result. It starts, locks door, I hear clicks as if it is cycling to next phase, but water does not fill the tub. This is a front load model. Anything missed before I part it out?
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Error code ESE
This is a problem whith your speed controll replace the the speed controll in the bootom of the washer
Fabric softener dispenser fills with water after every load
your overfilling it at start up ,,and its sphioning down only fill to metered line...and theres always alittle water in dispencer to keep it from sticking ,,but just a little..onthejob
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
